Thermal Sensors for LEGO® MINDSTORMS® NXT
Purchase:
Detailed Description
dThermal Series by Dexter Industries is a line of temperature sensors for the LEGO® MINDSTORMS® NXT system. The sensors offer an increased range of operating temperatures and a high level of accuracy.
These thermal sensors can easily be incorporated into chemistry, engineering, and environmental experiments with NXT-G and Labview.
Protected Thermal Probe
Constructed of 316 stainless steel, this rugged temperature probe is encased in a stainless steel shaft that can be used to measure temperatures in water, organics, ionic solutions, most acids, and bases.
The probe has a 1/4" OD, and is 6" long, making it ideal for most laboratory experiments and sealed distillation experiments. Solid construction offers superior strain relief.
Open Thermal Probe
This open thermal probe offers more rapid temperature readings. The probe is for use on dry surfaces and can be mounted to beakers, distillation columns, and other surfaces using steel bands.
The data line reaches 2 feet for flexibility of setup, and is hooked directly into the NXT. Solid construction and a rugged design with extra protection offers strain relief and a long lifetime.
Technical Specifications:
Protected Thermal Probe:
Open Thermal Probe:
- Temperature Operating Range: -50C (-58 F) to 150 C (302 F)
- Accuracy: +/- 0.5 C
- Response Time: 90% in 50 Seconds
- Precision:-50C - 0C +/-1 C
0C - 50C +/-0.1 C
50 C - 100C +/- 0.5 C
100 C - 150 C +/- 2 C
- Response Time: 90% in 25 Seconds
0C - 50C +/-0.1 C
Downloads
Visit our Downloads section for blocks, example programs, and projects for the dThermal.
More on the dThermometer Sensor
See some of the projects we've done with the dThermal sensors here and here .
