dPressure Sensors
Purchase:
Detailed Description
The dPressure is a pressure sensor for the LEGO® MINDSTORMS® NXT system capable of measuring up to 250 kPa (30 psi) and 500 kPa (70 psi) of pressure and gauge vacuum. The sensor comes with an adapter for LEGO Pneumatic lines.
The sensor is easy to use: it plugs directly into the NXT and users can be up and reading pressures in seconds.
These pressure sensors can easily be incorporated into chemistry, engineering, and environmental experiments with NXT-G and Labview.
Technical Specifications:
The dPressure sensor comes in two versions:
Both sensors measure differential pressure and have 1/8" ports.
- The dPressure 250: Vacuum to 250 kPa (30 PSI)
- The dPressure 500: Vacuum to 500 kPa (70 PSI)
These analog sensors can measure down to 0.25 kPa (0.04 PSI) in pressure change and has a response time of 1 ms.
Video
Downloads
Visit our Downloads section for blocks, example programs, and projects for the dPressure.
More on the dPressure Sensor
Check out Jojoguy's review of the dPressure sensor here and his work to datalog pressure in a pressure vessel using Lego Pneumatics.
