Tired of Turning off the Lights? Saving Electricity with the dSwitch and the TweetaWatt
Earlier we posted on how we used some free time over the holidays to make Adafruit’s Tweet-A-Watt project. We wanted to see if we could combine the device with the dSwitch and conserve some energy around the office. We wrote a quick program that “listens” for a human, and turns the lights off if no one is there. The program ended up saving some energy, which over the year, will save some dough. “How much you ask?” Read on . . .
The Office
The setup is pretty easy in our office: most of the appliances hook into one socket. Safety first though: I made sure that the dSwitch was properly sized, and the electrical load would not exceed the rated 10 Amps. In my particular area, I have a laptop, a printer, and a few lights hooked up. The laptop converter draws about 65 Watts at most, and I have a 100-Watt incandescent lightbulb, 2 14-Watt CFL light bulbs, and a printer that uses about 72 Watts. Sometimes I use my soldering iron, which draws about 50 Watts.
So my area uses about 315 Watts running at full blast, or about 2.625 Amps at 120 Volts. That gives me plenty of room for safety within the 10 Amp max load of the dSwitch.
The Setup
I went ahead and put all the plugs into a power strip, which went directly into the TweetAWatt device. You can see a picture below.
Next we hooked up a sound sensor and a dSwitch to our NXT Smartbrick. The sound sensor should be able to pickup the noises of someone in the office: typing, talking on the phone, etc.
The setup is shown to the left. I put it at my feet, which turned out to be a pretty good distance for catching the sounds of my presence, and not picking up noises from outside.
Programming
I wrote a quick program where I could set a timer, the Smartbrick would “listen” over a period of time, and if it detected a sound greater than the threshold for my presence, it would shut the power off until a sound over the threshold was detected. A copy of the program can be found here, and is shown below (you can click on the picture to get a better resolution).
The program works pretty well. Establishing proper noise thresholds was crucial; I spent a lot of time playing with it to get it right. The thresholds depend on the noise in the area, and any noise outside. The dSwitch turns off with the clearing of my throat; an easy way to turn the lights back on if I’ve been reading for a long period. In the setup, I used the NXT’s wall plug to keep the battery charged. I also turned the sleep settings off the Smart Brick.
Time
The first set of data I took was on a typical day; since days are not usually typical, I made sure to start taking data at 9 AM, and stopping at 5 PM; my days usually start earlier and end a lot later. But to keep the data straight, we started and ended at the same time. The idea is to go ahead and sum up all the wattage used over a normal day.
First Run: Saving Energy
We ran the energy saver program on a typical day. We simply hooked up the TweetAWatt and the receiver and started taking data.
The real-time results are graphed below. The data shows the ups and downs of the day in terms of watt usage. You can see a spike of wattage in the early part of the day as my laptop charges up (charging the battery consumes more electricity than normal usage). As that drops off you seem some drops when I take a bathroom break and step out for a phone call. Lunch is the big drop; when I take a half hour off about 12:00 to 12:30, the voltage drops as the dSwitch turns off the office. You can see a few more breaks during the day, and a spike of around 50 watts around 15:45 when I turn on the soldering iron.
  • Energy: The all in all, we used about 980 watt-hours in the day.
  • Cost: According to the Department of Energy, a KWH costs about 11.68 cents. I spent about 11.44 cents of electricity.
  • Carbon: In terms of carbon, according to carbonfund.org, the electricity we used generated about 1.27 lbs of carbon.
Baseline: Bringing it Home
Let’s make the data from our setup mean something. To do that, we need some baseline data: what does a typical day without the setup look like? Let’s see what the wattage looks like on a typical day.
Oops . . . that’s not a typical day. Or it’s a little bit off. What happened? I took my laptop into another room to work after lunch, left the lights on. You can see a pretty clear drop there after about 12:45. So this isn’t really good baseline data.
Baseline: Really Bringing it Home
Ok, here we go again a few days later. Same equipment, same time frame.
We got a pretty good read here. We get a pretty even average wattage consumption around 150 watts. Later in the day, about 14:45, I turned on the soldering iron. You can see the spike. Looks like we have some decent baseline data. The final numbers for the data are . . . .
  • Energy: I used about 1,300 watt-hours in the day.
  • Cost: I spent about 15.18 cents on electricity.
  • Carbon: I generated about 1.686 lbs of carbon.
All of the raw data from the experiments can be found in an Excel sheet on our website here.
What’s the Difference?
Let’s look at the raw data first. By using the dSwitch, on an average day we saved:
  • Energy: 320 watt-hours.
  • Cost: 3.74 cents.
  • Carbon: 0.416 lbs of carbon.
In a year (assuming I don’t work weekends) we save:
  • Energy: 76,800 watt-hours.
  • Cost: $8.98
  • Carbon: 100 lbs of carbon.
The Longer View
The numbers seem small, but let’s take a slightly longer view. The energy saver doesn’t save me much electricity, money, or carbon (unless I take those $9 a year, and save them for retirement . . . in 30 years, I have an extra $1,628.49). That ain’t a lot.
However . . . the DOE says that the average household electricity consumption is about 11,232 KWH. Not all of the house can be wired up this way, but if take the data from the DOE, 65% of household electricity is used in appliances. We can’t run the refrigerator this way, and refrigerators account for about 14% of household electricity. That’s about 50% or so that’s used for stuff that can be shut off when no one is around.
The data from the dSwitch experiment and the baseline suggest we can lower the energy usage by about 25%. So we can lower 50% of 11,232 KWHs by 25% . . . or save about 1,404 KWH in the average household per year. Ergo . . . final tally:
  • Energy Saved: 1,404,000 watt-hours.
  • Cost: $160.05
  • Carbon: 1,783 lbs of carbon.
That’s quite a bit of savings for the grid (energy), the dough (my wallet), and carbon (the environment).
Final Thoughts and Notes
Some appliances don’t cycle well. We mentioned the refrigerator above, and that could lead to a disaster. A little less painful is hooking your internet router up. Or desktop computer, or printer.
Watch the Youtube video here.
This entry was posted in Products and tagged , , , , , , , . Bookmark the permalink.
One Response to Tired of Turning off the Lights? Saving Electricity with the dSwitch and the TweetaWatt
  1. Pingback: Energy Saver NXT-G File | Downloads | Dexter Industries
