Thermal Infrared Sensor
Bookmark and Share
Thermal Infrared Sensor for Lego Mindstorms NXT from Dexter IndustriesComing soon from Dexter Industries:  a digital Thermal Infrared Sensor.
The thermal infrared is a sensor measures the temperature of objects without touching them, by measuring the infrared radiation coming off.  Infrared sensors are used in everything from night-vision to medical diagnostics.
Soon you’ll be able to measure the temperature of objects (and at the same time the ambient temperature!) just by pointing this sensor at something.  This sensor will be able to measure up to 380° C!
This entry was posted in News, Thermal Infrared Sensor and tagged , , , , , . Bookmark the permalink.
4 Responses to Thermal Infrared Sensor
  1. Paul says:
    What is the distance it can take reasonable readings from?
  2. John says:
    Paul,
    So for we’ve only tested detection at 2 meters. It should “see” heat from a little further, but we’re still testing it!
    John
  3. dineshkumargowd says:
    how much it costs????
  4. Administrator says:
