Getting Started
If you are just starting with the GrovePi, you should follow the Quick Start Guide to get your GrovePi up and running. Here’s a little video if you’d like to see the full walk thru, step by step.
4. Compatibility with Raspberry B+ & 2
6. Download the PDF version here.
Programming
If you are using the Dexter Industries Rapbian for Image or have already have set up the software, you can view all the examples and projects available for the GrovePi in various programming languages.
If you have not set up the software for the GrovePi, follow the Getting Started guide in the above section.
Programming in Python See our Video “Write Your First Program in Python” Python Library & Documentation |
Programming in Scratch: See our Video “Write Your First GrovePi Program in Scratch” |
Programming in Java GrovePi and Java with Netbeans and Maven |
For more information check the links below:
Projects
Here are some of the fun projects that you can build with the GrovePi:
Technical Information and Troubleshooting
Accessories
Grove Sensors for the Raspberry Pi: Officially supported and Tested
These Grove modules have been tested by Dexter Industries and the GrovePi community and have examples available to try them out in our Github repository
Grove – Temperature and Humidity Sensor Pro |
Compatible Sensors
The Grove modules at Grove Wiki have not been tested but most of them are compatible with the GrovePi either by directly using the Python code or making changes to the firmware. (Check the Design page for more details)
Questions or a problem? Post it on the forums and we’ll help you out.
Questions
Technical questions about the GrovePi+? Post it on the forums and we’ll help you out!
