#! /bin/bash PIHOME=/home/pi DEXTER=Dexter DEXTER_PATH=$PIHOME/$DEXTER RASPBIAN=$PIHOME/di_update/Raspbian_For_Robots GOPIGO3_DIR=$DEXTER_PATH/GoPiGo3 DEXTERSCRIPT=$DEXTER_PATH/lib/Dexter/script_tools # the top-level module name of each package # used for identifying present packages REPO_PACKAGE=gopigo3 # the following option specifies which GoPiGo3 github branch to use selectedbranch="master" ############################################## ######## Parse Command Line Arguments ######## ############################################## # called way down bellow check_if_run_with_pi() { ## if not running with the pi user then exit if [ $(id -ur) -ne $(id -ur pi) ]; then echo "GoPiGo3 installer script must be run with \"pi\" user. Exiting." exit 6 fi } # called way down below parse_cmdline_arguments() { # whether to install the dependencies or not (avrdude, apt-get, wiringpi, and so on) installdependencies=true updaterepo=true install_rfrtools=true install_pkg_rfrtools=true install_rfrtools_gui=true # the following 3 options are mutually exclusive systemwide=true userlocal=false envlocal=false usepython3exec=true # selectedbranch=master # "selectedbranch" variable can be found up top in the code declare -ga rfrtools_options=("--system-wide") # iterate through bash arguments for i; do case "$i" in --no-dependencies) installdependencies=false ;; --no-update-aptget) updaterepo=false ;; --bypass-rfrtools) install_rfrtools=false ;; --bypass-python-rfrtools) install_pkg_rfrtools=false ;; --bypass-gui-installation) install_rfrtools_gui=false ;; --user-local) userlocal=true systemwide=false declare -ga rfrtools_options=("--user-local") ;; --env-local) envlocal=true systemwide=false declare -ga rfrtools_options=("--env-local") ;; --system-wide) ;; develop|feature/*|hotfix/*|fix/*|DexterOS*|v*) selectedbranch="$i" ;; esac done # show some feedback on the console if [ -f $DEXTERSCRIPT/functions_library.sh ]; then source $DEXTERSCRIPT/functions_library.sh # show some feedback for the GoPiGo3 if [[ quiet_mode -eq 0 ]]; then echo " _____ _ "; echo " | __ \ | | "; echo " | | | | _____ _| |_ ___ _ __ "; echo " | | | |/ _ \ \/ / __/ _ \ '__| "; echo " | |__| | __/> <| || __/ | "; echo " |_____/ \___/_/\_\\\__\___|_| _ "; echo " |_ _| | | | | (_) "; echo " | | _ __ __| |_ _ ___| |_ _ __ _ ___ ___ "; echo " | | | '_ \ / _\ | | | / __| __| '__| |/ _ \/ __| "; echo " _| |_| | | | (_| | |_| \__ \ |_| | | | __/\__ \ "; echo " |_____|_| |_|\__,_|\__,_|___/\__|_| |_|\___||___/ "; echo " "; echo " "; echo " ____ ____ _ ____ _____ " echo " / ___| ___ | _ \(_)/ ___| ___|___ / " echo " | | _ / _ \| |_) | | | _ / _ \ |_ \ " echo " | |_| | (_) | __/| | |_| | (_) |__) |" echo " \____|\___/|_| |_|\____|\___/____/ " echo " " fi feedback "Welcome to GoPiGo3 Installer." else echo "Welcome to GoPiGo3 Installer." fi echo "Updating GoPiGo3 for $selectedbranch branch with the following options:" ([[ $installdependencies = "true" ]] && echo " --no-dependencies=false") || echo " --no-dependencies=true" ([[ $updaterepo = "true" ]] && echo " --no-update-aptget=false") || echo " --no-update-aptget=true" ([[ $install_rfrtools = "true" ]] && echo " --bypass-rfrtools=false") || echo " --bypass-rfrtools=true" ([[ $install_pkg_rfrtools = "true" ]] && echo " --bypass-python-rfrtools=false") || echo " --bypass-python-rfrtools=true" ([[ $install_rfrtools_gui = "true" ]] && echo " --bypass-gui-installation=false") || echo " --bypass-gui-installation=true" echo " --user-local=$userlocal" echo " --env-local=$envlocal" echo " --system-wide=$systemwide" # create rest of list of arguments for rfrtools call rfrtools_options+=("$selectedbranch") [[ $usepython3exec = "true" ]] && rfrtools_options+=("--use-python3-exe-too") [[ $updaterepo = "true" ]] && rfrtools_options+=("--update-aptget") [[ $installdependencies = "true" ]] && rfrtools_options+=("--install-deb-deps") [[ $install_pkg_rfrtools = "true" ]] && rfrtools_options+=("--install-python-package") [[ $install_rfrtools_gui = "true" ]] && rfrtools_options+=("--install-gui") echo "Using \"$selectedbranch\" branch" echo "Options used for RFR_Tools script: \"${rfrtools_options[@]}\"" } ################################################# ########## Cloning GoPiGo3 & RFR_Tools ########## ################################################# # called in <> check_dependencies() { command -v git >/dev/null 2>&1 || { echo "This script requires \"git\" but it's not installed. Error occurred with RFR_Tools installation." >&2; exit 1; } command -v python2 >/dev/null 2>&1 || { echo "Executable \"python2\" couldn't be found. Error occurred with RFR_Tools installation." >&2; exit 2; } command -v pip >/dev/null 2>&1 || { echo "Executable \"pip2\" couldn't be found. Error occurred with RFR_Tools installation." >&2; exit 3; } if [[ $usepython3exec = "true" ]]; then command -v python3 >/dev/null 2>&1 || { echo "Executable \"python3\" couldn't be found. Error occurred with RFR_Tools installation." >&2; exit 4; } command -v pip3 >/dev/null 2>&1 || { echo "Executable \"pip3\" couldn't be found. Error occurred with RFR_Tools installation." >&2; exit 5; } fi if [[ ! -f $DEXTERSCRIPT/functions_library.sh ]]; then echo "script_tools didn\'t get installed. Enable the installation of dependencies with RFR_Tools.'" exit 8 fi } # called way down below install_rfrtools_repo() { # if rfrtools is not bypassed then install it if [[ $install_rfrtools = "true" ]]; then curl --silent -kL https://raw.githubusercontent.com/DexterInd/RFR_Tools/$selectedbranch/scripts/install_tools.sh > $PIHOME/.tmp_rfrtools.sh echo "Installing RFR_Tools. This might take a while.." bash $PIHOME/.tmp_rfrtools.sh ${rfrtools_options[@]} # > /dev/null ret_val=$? rm $PIHOME/.tmp_rfrtools.sh if [[ $ret_val -ne 0 ]]; then echo "RFR_Tools failed installing with exit code $ret_val. Exiting." exit 7 fi echo "Done installing RFR_Tools" fi # check if all deb packages have been installed with RFR_Tools check_dependencies source $DEXTERSCRIPT/functions_library.sh } # called way down bellow clone_gopigo3() { # $DEXTER_PATH is still only available for the pi user # shortly after this, we'll make it work for any user sudo mkdir -p $DEXTER_PATH sudo chown pi:pi -R $DEXTER_PATH cd $DEXTER_PATH # it's simpler and more reliable (for now) to just delete the repo and clone a new one # otherwise, we'd have to deal with all the intricacies of git sudo rm -rf $GOPIGO3_DIR git clone --quiet --depth=1 -b $selectedbranch https://github.com/DexterInd/GoPiGo3.git cd $GOPIGO3_DIR } ################################################ ##### Install Python Packages & Services ####### ################################################ # called by <> install_python_packages() { [[ $systemwide = "true" ]] && sudo python2 setup.py install \ && [[ $usepython3exec = "true" ]] && sudo python3 setup.py install [[ $userlocal = "true" ]] && python2 setup.py install --user \ && [[ $usepython3exec = "true" ]] && python3 setup.py install --user [[ $envlocal = "true" ]] && python2 setup.py install \ && [[ $usepython3exec = "true" ]] && python3 setup.py install } # called by <> remove_python_packages() { # the 1st and only argument # takes the name of the package that needs to removed rm -f $PIHOME/.pypaths # get absolute path to python package # saves output to file because we want to have the syntax highlight working # does this for both root and the current user because packages can be either system-wide or local # later on the strings used with the python command can be put in just one string that gets used repeatedly python2 -c "import pkgutil; import os; \ eggs_loader = pkgutil.find_loader('$1'); found = eggs_loader is not None; \ output = os.path.dirname(os.path.realpath(eggs_loader.get_filename('$1'))) if found else ''; print(output);" >> $PIHOME/.pypaths sudo python2 -c "import pkgutil; import os; \ eggs_loader = pkgutil.find_loader('$1'); found = eggs_loader is not None; \ output = os.path.dirname(os.path.realpath(eggs_loader.get_filename('$1'))) if found else ''; print(output);" >> $PIHOME/.pypaths if [[ $usepython3exec = "true" ]]; then python3 -c "import pkgutil; import os; \ eggs_loader = pkgutil.find_loader('$1'); found = eggs_loader is not None; \ output = os.path.dirname(os.path.realpath(eggs_loader.get_filename('$1'))) if found else ''; print(output);" >> $PIHOME/.pypaths sudo python3 -c "import pkgutil; import os; \ eggs_loader = pkgutil.find_loader('$1'); found = eggs_loader is not None; \ output = os.path.dirname(os.path.realpath(eggs_loader.get_filename('$1'))) if found else ''; print(output);" >> $PIHOME/.pypaths fi # removing eggs for $1 python package # ideally, easy-install.pth needs to be adjusted too # but pip seems to know how to handle missing packages, which is okay while read path; do if [ ! -z "${path}" -a "${path}" != " " ]; then echo "Removing ${path} egg" sudo rm -f "${path}" fi done < $PIHOME/.pypaths } # called way down bellow install_python_pkgs_and_dependencies() { # installing dependencies if required if [[ $installdependencies = "true" ]]; then pushd $GOPIGO3_DIR/Install > /dev/null sudo bash ./install.sh popd > /dev/null fi feedback "Removing \"$REPO_PACKAGE\" to make space for the new one" remove_python_packages "$REPO_PACKAGE" # installing the package itself pushd $GOPIGO3_DIR/Software/Python > /dev/null install_python_packages popd > /dev/null # install control panel on desktop if [[ -d $PIHOME/Desktop ]]; then cp $GOPIGO3_DIR/Software/Python/Examples/Control_Panel/gopigo3_control_panel.desktop $PIHOME/Desktop/gopigo3_control_panel.desktop fi # install calibration panel on desktop if [[ -d $PIHOME/Desktop ]]; then cp $GOPIGO3_DIR/Software/Python/Examples/Calibration_Panel/gopigo3_calibration.desktop $PIHOME/Desktop/gopigo3_calibration.desktop fi # install openocd echo "Installing OpenOCD for GoPiGo3" curl --silent https://raw.githubusercontent.com/DexterInd/openocd/master/openocd_install.sh | bash } # called way down bellow install_gopigp3_power_service() { # Install the system services sudo cp $GOPIGO3_DIR/Install/gpg3_power.service /etc/systemd/system sudo chmod 644 /etc/systemd/system/gpg3_power.service sudo systemctl daemon-reload sudo systemctl enable gpg3_power.service sudo systemctl start gpg3_power.service } install_list_of_serials_with_16_ticks() { cp $GOPIGO3_DIR/Install/list_of_serial_numbers.pkl $DEXTER_PATH/.list_of_serial_numbers.pkl } ################################################ ######## Call all functions - main part ######## ################################################ check_if_run_with_pi parse_cmdline_arguments "$@" install_rfrtools_repo clone_gopigo3 install_python_pkgs_and_dependencies install_gopigp3_power_service install_list_of_serials_with_16_ticks installresult=$(python3 -c "import gopigo3; g = gopigo3.GoPiGo3()" 2>&1) if [[ $installresult == *"ModuleNotFoundError"* ]]; then echo "GOPIGO3 SOFTWARE INSTALLATION FAILURE: "+$installresult echo "Suggest installing over Legacy Pi OS (Buster)." elif [[ $installresult == *"IOError"* ]]; then echo "No SPI response. GoPiGo3 not detected: "+$installresult echo "Ensure SPI is enabled in raspi-config." elif [[ $installresult == *"FirmwareVersionError"* ]]; then echo "GoPiGo3 detected with a firmware issue: " echo $installresult echo "Suggest reflashing the firmware using the script in ~/Dexter/GoPiGo3/Firmware." else echo "GOPIGO3 SOFTWARE INSTALLATION SUCCESSFUL." fi exit 0
