#! /bin/bash # This is the master script for updating Raspbian for Robots. # All updates should be run from this script. # This script should RARELY be changed. ############################################################################################################## # 0. Check for internet connection. echo " " echo "Check for internet connectivity..." echo "==================================" if ping -c 1 8.8.8.8 &> /dev/null; then echo "Connected. Do not close this window!" sleep 1 else echo "Unable to Connect, try again !!!" echo "Connect your Pi to the internet and try again." echo "This window will close in 10 seconds." sleep 10 exit 0 fi # sudo sh -c "curl -kL dexterindustries.com/update_tools | bash" PIHOME=/home/pi DEXTER=Dexter DEXTER_PATH=$PIHOME/$DEXTER DEXTER_LIB=lib DEXTER_LIB_PATH=$DEXTER_PATH/$DEXTER_LIB DEXTER_SCRIPT_TOOLS=$DEXTER/script_tools DEXTER_SCRIPT_TOOLS_PATH=$DEXTER_LIB_PATH/$DEXTER_SCRIPT_TOOLS VERSION=$(sed 's/\..*//' /etc/debian_version) source $DEXTER_SCRIPT_TOOLS_PATH/functions_library.sh ############################################################################################################## # 1. Update the Source Files. Pull the Raspbian for robots Github repo and put it in a subdirectory of pi. # Get the latest update information. # If the directory exists, delete it. if [ -d /home/pi/di_update ] ; then sudo rm -r /home/pi/di_update fi # Make the directory again. Clone into it. mkdir /home/pi/di_update cd /home/pi/di_update sudo git clone --depth=1 https://github.com/DexterInd/Raspbian_For_Robots/ cd /home/pi/di_update/Raspbian_For_Robots/ # # Take this part out when you're done! # git checkout develop # ############################################################################################################## # 3. Execute the file update_all.sh # Make sure we keep a log file. if [ $VERSION -eq '10' ]; then sudo apt-get install python-wxgtk3.0 build-essential python-psutil python-dev python-pip -y else sudo apt-get install python-wxgtk3.0 python-wxgtk2.8 build-essential python-psutil python-dev python-pip -y fi # Run update_all.sh NOW=$(date +%m-%d-%Y-%H%M%S) LOG_FILE="/home/pi/di_update/log_output.$NOW.txt" # Start raspbian_for_robots_update.py # This is the GUI that will let you choose to: # 1. OS Update # 2. DI Software Update # 3. DI Hardware Update echo "START UPDATE GUI." echo "==============================" # sudo python /home/pi/di_update/Raspbian_For_Robots/raspbian_for_robots_update.py today=`date '+%Y_%m_%d__%H_%M_%S'`; filename="/home/pi/Desktop/Dexter_Software_Update_log_$today.txt" script -c 'sudo python /home/pi/di_update/Raspbian_For_Robots/raspbian_for_robots_update.py 2>/dev/null' -f $filename delete_file /home/pi/index.html* ############################################################################################################## # 4. Reboot the Pi. # We must reboot for folks. echo "To finish any changes, we need to reboot the Pi." echo "Pi must reboot for changes and updates to take effect." # echo "Rebooting in 5 seconds!" # sleep 1 # echo "Rebooting in 4 seconds!" # sleep 1 # echo "Rebooting in 3 seconds!" # sleep 1 # echo "Rebooting in 2 seconds!" # sleep 1 # echo "Rebooting in 1 seconds!" # sleep 1 # echo "Rebooting now! Your Pi wake up with a freshly updated Raspberry Pi!" # sleep 1 # sudo reboot
