#! /bin/bash PIHOME=/home/pi DEXTER=Dexter LIB=lib DEXTER_PATH=$PIHOME/$DEXTER/$LIB/$DEXTER DEXTER_SCRIPT=$DEXTER_PATH/script_tools selectedbranch=master ################################################ ######## Run a series of checks ################ ################################################ # called way down bellow check_if_run_with_pi() { ## if not running with the pi user then exit if [ $(id -ur) -ne $(id -ur pi) ]; then echo "script_tools installer script must be run with \"pi\" user. Exiting." exit 2 fi } check_dependencies() { command -v git >/dev/null 2>&1 || { echo "installing git"; sudo apt install git -y; } } ################################################ ########### Parse arguments #################### ################################################ parse_arguments() { # iterate through bash arguments for i; do case "$i" in develop|feature/*|hotfix/*|fix/*|DexterOS*|v*) selectedbranch="$i" ;; esac done } ################################################ ######## Cloning script_tools ################# ################################################ clone_scriptools(){ # create folders recursively if they don't exist already # can't use <> here because there's no # cloned script_tools yet at this part of the install script pushd $PIHOME > /dev/null sudo mkdir -p $DEXTER_PATH sudo chown pi:pi -R $PIHOME/$DEXTER popd > /dev/null # it's simpler and more reliable (for now) to just delete the repo and clone a new one # otherwise, we'd have to deal with all the intricacies of git sudo rm -rf $DEXTER_SCRIPT pushd $DEXTER_PATH > /dev/null git clone --quiet --depth=1 -b $selectedbranch https://github.com/DexterInd/script_tools.git cd $DEXTER_SCRIPT # useful in case we need it current_branch=$(git branch | grep \* | cut -d ' ' -f2-) popd > /dev/null } ################################################ ######## Aggregating all function calls ######## ################################################ check_if_run_with_pi parse_arguments "$@" check_dependencies clone_scriptools exit 0
