This is an advanced project with the GoPiGo. In this example we use a GPS sensor with the GoPiGo. Users can use the GPS data to program waypoints for the GoPiGo and create a GPS guided bot using the GoPiGo.
Hardware needed:
- A fully assembled GoPiGo
- Wifi Dongle for connecting and controlling
- Grove GPS sensor
Connecting the GPS
- Take a Grove connector and take out the yellow and white cables and cross them over, so that the connector is now “BRYW” from the original “BRWH” configuration.
- Now attach one end of the cable to the GPS and the other end to the Serial port on the top side of the GoPiGo
- Now fix the entire module on the top plate using screws and mounting holes
Setting up the GoPiGo
Running the example:
- Go to the GPS bot example folder:
cd Desktop/GoPiGo/Software/Python/Examples/GPS Bot/
- Start the basic_robot_control.py example
sudo python gps.py
You can easily adapt this example to any project that you have in mind with the GoPiGo and the GPS sensor.
Have a question? Go check out our support page here or post it on the forums here.
