The GrovePi+ is compatible with the Raspberry Pi Model B+ and the Raspberry Pi 2 and the Raspberry Pi 3. Below we have included some pictures to show the Raspberry Pi Model B+ and Raspberry Pi Model 2 with the GrovePi+ attached.
You should be careful when mounting the GrovePi+ to the Raspberry Pi Model B+ and Model 2. Both come with a 40 pin header while the GrovePi+ comes with a 26 pin header. If you mount it incorrectly, it can cause damage to the GrovePi+ and the Raspberry Pi.
The pin on the GPIO header on the GrovePi marked as “1” should go into the Raspberry Pi header pins on the top left corner, far from the USB ports and the micro USB power connector. Refer the pictures below and make sure that you have connected the GrovePi+ properly before powering it on.
GrovePi Case Assembly
Have a question or a problem? Post it on the forums and we’ll help you out.
