NXC Examples Added for NXTBee Sensors
NXTBee Sensor for Lego Mindstorm NXT on a Mindstorm Brick.
With a growing number of folks requesting NXC for Mindstorms NXT examples for the NXTBee, we’ve been working on getting more example code up.  This example is a very bare-bones one to get started in NXC.  It makes getting started with the NXTBee easier and faster . . .
There are two parts to this.
The first initializes the NXTBee radio and resets all the defaults.  It allows the user to set the baud rate from the NXT.  You can download it here:  http://www.dexterindustries.com/files/nxtbee_Setup.zip
The second batch is an example transmission and receive code for two NXT’s to talk to each other with the NXTBee sensors.  You can download it here:  http://www.dexterindustries.com/files/NXTBeeRawForNXC.zip
To run both of these examples, you must be using the latest release of NXC (1.2.1 r4 or later).  You can find it at http://bricxcc.sourceforge.net/nbc/
Special thanks to John Hansen who helped make this possible.  The code was adapted from Xander’s work in RobotC.
See more about the NXTBee Sensors for the Mindstorm NXT here.
As always, you can find this in our Downloads section.
2 Comments
  1. Jan Kromhout April 10, 2011
    Hello,
    This is a nice device.
    Can this replace the “Poor” Bluetooth connection with a PC?
    Cheers,
    Jan Kromhout
    Hellevoetsluis-NL
    • Administrator April 10, 2011
      Yes, this is a great replacement for bluetooth. It’s not only easier to use, but it is more better in distance and speed.
