The PivotPi Base Kit is perfect for getting started with animated robot projects! Code anything in your world to move with 4 small servo motors and 2 large, powerful ones. This is a kit that includes the PivotPi board, battery pack, 2 large servo motors and 4 small servo motors. Now you can program your robotics, automation, and art projects to move!
The PivotPi is a complete kit to turn anything in your world into a moving robot. The PivotPi is a servo controller for the Raspberry Pi. It can control up to 8 servos, allowing you to make projects that move, grab, dance, swing, wave, and many other motions. You can use the PivotPi to create robots, automate your home, make moving sculptures, and craft animatronics built with the Raspberry Pi. The PivotPi can be programmed using Python, Scratch, and many other programming languages.
This is a set of 2 large servo motors that you can connect to the PivotPi to make your robots and projects rotate! The servos come with various plastic adapters for connecting to your robotics, automation, and art projects.
This is a set of 4 small servos that you can connect to the PivotPi to make your robots and projects rotate! The servos come with various plastic adapters for connecting to your robotics, automation, and art projects.
The PivotPi Starter Kit includes everything you need to get started building animated robot projects! This kit includes the PivotPi board, battery pack, 2 large servo motors and 4 small servo motors, Raspberry Pi, Ethernet Cable, Power Adapter, Wifi Dongle, and SD card.
Measure bending motions and make robots that mimic you. dFlex flexible sensor measures angular displacement, or bend, of the sensor. The sensor bends and flexes with mechanical motion. dFlex does not work with EV3.
Strictly Necessary Cookies
3rd Party Cookies
