Cheers!
Cheers!
There are at least two steps in simple brewing where the temperature is critical. The first step is steeping, where a grain is heated to temperature, about 65 C. This step is less mission critical: the grains can burn, but as long as it’s not boiling, we’re still good. Still, the brewing requires some attention. And it’s not fun to keep checking the temperature and adjusting the gas flame every few minutes. You can see our steeping on the right. Every few minutes, we check the temperature. This goes on for about 30 minutes or so . . . 30 minutes of your life you can never get back.
The second temperature-critical step in brewing is “The Boil”. This is where things get interesting. The brew has to be brought to a boil, ingredients added, and then maintained at a boil for almost an hour. The purpose is to bring everything into solution, disperse for taste, and make the brew sterile. Here’s where it can get really dangerous: the brew needs to boil (in part to kill any bacteria that might compete with the yeast), but it can’t boil over. The brew must be kept at boiling, and not over. A worst case scenario: you over boil the pot, you lose some future beer, and hardened burned sugar lights on fire and coats the stove-top when your wife gets home (Sorry).
Our stove is a natural gas burner. The results are on the right. No matter how attentive we were, the brew boiled over more than once. You can see some of the damage; the pot is hiding the big black burned sugar chunk underneath. It took an hour to clean up. We were almost banished from the kitchen.
