We set out to put the new Dexter Industries Thermometers  through trials.  How accurate is it?  How quickly does it respond to temperature changes?  What kind of resolution do we get with it?  Just how good is the thermometer?
First, Brian Davis wrote a great blog entry about the Lego thermometers and a really nice analysis of their performance. His entry gives a great baseline for comparison of the hardware already on the market . . .
In NXT-G, the average delta, or error, was -0.28 C. In Labview, the average error was about -0.498.
h illustrates the different response times of the open thermometer (in yellow) and the protected thermometer (in blue). The response times were:
Open: 26.7 S (90%)
Protected: 50.4 Seconds (90%)
Resolution: How precise can we be? We went about calculating resolution in two ways: theoretical and experimental. Because of the nature of the thermomister in the thermometers, the resolution varies over the range of measured temperatures. The thermometer should become more precise in the middle (higher resolution), between 0 C and 100 C, and begin to lose resolution outside that range.
Room for Improvement:
While the analog thermometers are reasonably accurate for work between 0 and 100 Celsius, at the edges of this range, it becomes less precise. What can we do about it?
